  3. Fotos e Vídeos
  4. John shepherd, eclipse
20 Posts 13 Posters 2.5k Visualizações
    e ouvi dizer que o pellegrini pediu um motor desse do usa pro eclipse dele.
      daniel
      [snapback]606539[/snapback]
      ? aquele um que estava em montagem que ira correr na pro mod ??
        esse carro tem tração 4x4. verdadeiro dragão mesmo…
          Mega
          paguei pau.
            [snapback]606541[/snapback]
            sim…esse mesmo
              daniel
              sim…esse mesmo
              [snapback]606702[/snapback]
              queria ver ele dando coro no ybl
                daniel
                chassis & interior
                factory unibody chassis
                autometer gauges
                all steel except for hood and hatch
                gary reese 7.49 certified cage
                momo steering wheel
                kirkey seat
                jic coilover suspension
                the brake man front and rear brakes
                volk 15x7 bronze te-37 wheels
                mickey thompson et drag tires
                engine
                buschur racing 2.0l short block
                je pistons
                groden aluminum rods
                eagle 4340 crankshaft
                hard block filled block
                stock oil pump and pan
                fox lake power products cylinder head
                race port intake and exhaust
                1mm ferrea intake valves
                1mm ferrea exhaust valves
                ferrea dual valve spring
                o-ringed deck
                custom grind crane cams
                unorthodox cam gears
                ams vsr intake manifold with 90mm throttle body
                fuel, ignition, & engine management
                buschur racing dual fuel rails
                10 x 1600 cc injectors
                methanol fuel
                3 gallon fuel cell
                waterman mechanical fuel pump
                aem engine management
                aem wideband kit
                aem injector driver box
                msd dis 2 ignition box
                buschur racing coil on plug coils
                16v turbostart battery
                nitrous express nitrous system jetted for 100 hp
                drivetrain
                sheptrans.com dog box transmission
                act carbon clutch
                the driveshaft shop aluminum driveshaft
                the driveshaft shop transfer case upgrade
                the driveshaft shop stage 5 front axles
                turbo & exhaust
                forced performance 321 stainless header
                tial blow off valves
                tial 44mm wastegate
                forced performance gt42r turbo
                ams 3.5 upper pipe
                forced performance 3.5 side exit exhaust
                hallman boost controller set to 55 psi
                  4cil 2000cc????
                  ta loko
                  babei
                    55 psi
                    :putz:
                      3.85 bar…
                      mermao, isso é tempo/velocidade do degreas...
                      mais o cara tem 2 cil. a menos de 1/3 da cilindrada pqp
                      quem disse que no have replacement for displacement? :putz:
                        FabioRR
                        esse da? segue o lema:
                        quem tem medo de pressão, é art?ria entupida
                          gabriel
                          pqp sem palavras…
                            Le
                            carrao mesmo
                            lembro dele quebrando o cambio na final da nopi de 2005
                            voou pedaão pra tudo quanto é lado.
                              BRUTaL DLX
                              du caralho este
                                Bruno Ramos
                                nossa, animal demais esse eclipse…
                                gagina ele alinhando com o ybl e com a ss-10 do alexandre...
                                  turbocahrger is the best replacement for displacement.
                                    Mega
                                    segundo me consta, esse carro é 2.7 lts.
                                      fraco… fraco nao ... raquitico
